00 Civic EX -- Flickering lights
Old Sep 27, 2010 | 03:54 AM
brianjec's Avatar
Default 00 Civic EX -- Flickering lights
I have a 00 civic ex, I've been having a problem lately with my lights rapidly pulsing under certain load conditions. It rarely happens at idle but most often when cruising at highway speeds. I had my charging system checked at the parts store and it checked out fine. Cleaned the battery terminals, new plugs and wires. Also when idling if I just tap the gas slightly the rpm will drop back down to about 250 for maybe 5-10 seconds and then return to normal about 500. Any ideas on what would cause the light problem and rpm drop? Would a corroded distributor cap or rotor cause this? Any help is appreciated, thanx in advance.
Old Sep 27, 2010 | 07:14 AM
dxlol's Avatar
Default Re: Flickering lights
are they HID's or just normal bulbs?
Old Sep 27, 2010 | 10:13 AM
brianjec's Avatar
Hid low beam, but the headlights dont flicker, just everything else, dash lights dome light climate control parking lights.
Old Sep 27, 2010 | 05:44 PM
Former User's Avatar
With the engine off, what voltage do you measure across the battery terminals?
With the engine idling and everything electrical off, what voltage do you measure across the battery terminals?
With the engine idling and the high beams, HVAC, and rear defroster on, what voltage do you measure across the battery terminals?
HeresOtis
18
Mar 24, 2017 08:42 AM
4dr_Noob
Aug 12, 2012 06:41 AM
justinwebb
Mar 9, 2009 11:45 AM
mathetas
Honda Civic (2001 - 2005)
14
Sep 29, 2007 09:24 AM
