Warning to those rolling on Spoon Calipers
Make sure you put anti-seize on the allen head long bolts/shafts that hold the pad in place. I snapped one of them a year ago. The broken piece was stuck in the hole and I had to go thru the hassle of drilling it out and replacing it with something else. Last night I snapped another 2......
Just make sure you put anti-seize on them, or swap them out with some bolts with a slightly smaller diameter (so it slides thru the hole) with a locking nut on the other side.
Hmmm, how many miles you have on them? I have not had any problems at all, and have not put any anti seize on them.
Last night when I tried to swap pads and bed them in, both bolts on the passenger side seized and snapped. It didn't take much force to twist them off.
I've had the calipers for almost 3 years. Maybe the steel starts to deteriorate?
do you drive your car during winter on roads that use salt? that could lead to a corrosion problem that florida people are not seeing.
Just for a peace of mind, put some anti-seize on it. It doesn't cost much anyway.
[Modified by Wai, 3:06 PM 9/20/2002]
The only thing that won't stand up to the rigors of the track is the anti-seize. That stuff has the tendancy to smoke, burn and even catch fire if you heat it up enough on the track. I have had the Spoon calipers for 3 years and have never used anti-seize compound and have had no problems.
What kind of anti-seize did that?
Jus the good'ol copper looking stuff you basically paint on with that cheezy little brush. Okay, it's never actually caught fire but it will burn off and smoke like a bitch
The problem that you could be experienceing, is electrolysis. Where the dissimilar metals, when put together, tend to oxidize more rapidly then they would alone.
Anit-Sieze should cure all though.
