lsvtec wont crank new battery new starter new terminals
lsvtec wont crank for some strange reason when i go to try to crank the car the headlights dim startr doesnt turn over or nothing. fuel pump primes like it suppose to.. now im also having a problem where the postive cable wire is getting hella hot. so i bought new terminals and having the same issues... i need some help im starting to get aggravated with my car thanks...............
ok i just checked all grounds and added one one the intake still wont crank. so what did next was to take some wire and put one end on the starter and one end on the postive battery and the car didnt crank either im getting sooo aggravated.../
rubber piece on the starter is there any way possible you can send me a pic of the rubber peice that your talking about
take off the grounds and clean the mating surfaces with sandpaper or wire brush, especialy the ground that bolts from the gearbox to the chassis.
ProfMore
Oct 11, 2017 06:29 PM
