Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Help Please!
Old Sep 25, 2010 | 11:25 AM
bruisedcivic's Avatar
Default Help Please!
2002 Civic EX coupe, 191k miles, it is an original California car (different emissions). On my way home the engine light flashed on and off and my gauges started bouncing around. Leaving my car stranded. I could hear relays clicking by the ECU. Now it has no spark and the relays no longer click on. The check engine light won't come on when key is in "on" position either. Any help would be appreciated.
Old Sep 27, 2010 | 06:07 PM
Default Re: Help Please!
BUMP^^ help please
Old Sep 27, 2010 | 06:16 PM
BYUFAN's Avatar
Sounds like you are loosing electrical. Check your battery connections, alt connections, fuses, ect.
Old Sep 30, 2010 | 02:41 PM
suds1485's Avatar
problem happened to me to on a different honda. my crank pulley fell off. doubt thats your problem though
Old Oct 1, 2010 | 04:39 PM
It Wasn't Me's Avatar
Have you checked the battery cables and grounds?
Is the battery good? Do any of the exterior lights or dash lights come on when you turn the light switch on?
I know you said the check engine light doesn't come on, but what about any of the other indicators in the cluster? Do they come on?
Might be a fried ECU, might be as simple as a bad ignition switch. Might be... .. ...
vashachiroku
Sep 4, 2013 05:40 PM
sianzsianz
Jul 12, 2006 07:20 AM
Speed_69
Apr 14, 2006 04:48 PM
civicgeek133
Apr 11, 2006 06:34 PM
