Boost leak? Dyno chart included
From the way the power climb, look like i have a boost leak somewhere? the power never flatten out and keep climbing until redline?
Graph is in MPH 8000 redline
what is the torque curve look like?. if the tq holds flat then it could be just the turbo/cam setup in your motor. (my power keeps going up until around 8000 where it holds flat till 9000.
also, can you datalog with your management?
This is a dyno for a LS turbo set-up on the same dyno, the power peak and flatten but on mine which is ls-vtec it just climb and never flatten out
