99 civic si: Spun a rod bearing and need help figuring out replacement parts
Old Sep 24, 2010 | 05:21 PM
venomousracin's Avatar
Default 99 civic si: Spun a rod bearing and need help figuring out replacement parts
ok fellas i just bought a 99civic si, the engine spun a rod bearing (cyl4)the engine it has is a b16 block with itr pistons and p72 rods which are gsr i was told not sure what crank it has dont know how to identify it but anyways the head is a gsr. well i took the crank to a machine shop they said its no good and also my rods and pistons are seized but my dilemma is that i dont know what i should replace the damage parts with plz help me out i want and share ur knowledge with me
dont know if i should go with the same old set up he had done to it or if i should just go back to b16
Old Sep 24, 2010 | 05:40 PM
Former User's Avatar
Default Re: 99 civic si: Spun a rod bearing and need help figuring out replacement parts
An informative thread title is required and helps you get more responses by letting members know what specific information you need:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Thread title edited.
Old Sep 24, 2010 | 07:56 PM
thumper64's Avatar
Holy detonation Batman, I can't see that being possible. The pistons would stick out of the block about 1/8" and you would have had 15:1 compression
Old Sep 24, 2010 | 09:09 PM
inline4's Avatar
the head may be the only salvageable piece. if the valves on the head aren't bent to crap, if they are just replace them, then just find a stock b18c, b18c1, b18c5 block and mate it up to your p72 head. there's really no point in finding another b16 block unless it's a really good deal. i would say b18b or b20 too, but i'm not a big fan of ls/vtec.. to each his own, it's up to you.
Old Sep 24, 2010 | 09:36 PM
Deetz's Avatar
Crazy Honda Guy
It sounds like something is up with that engine. You can't use P72 rods in a B16 block, they would be too long. The pistons would be lower compression that B16 pistons, so that doesn't make sense either!
You sure the engine you have, isn't a B18C? Anyway, just buy a new engine and call it a day
Old Sep 24, 2010 | 09:40 PM
yeah this engine set up is mind boggling
ok well i dont know if this would make a diff but but i was just told that this block is a ctr block its stamp b16b and has hmo right next to it and on the back of the block its stamped p72 which is gsr right???
Old Sep 24, 2010 | 09:54 PM
sorry bout the heading new to this site but thanks for the info
Old Sep 24, 2010 | 10:09 PM
Deetz's Avatar
Crazy Honda Guy
ok, if it is a B16B, that is a Civic Type R block (CTR). That is the exact same block as a gsr and Type R, so that makes more sense now
Old Sep 25, 2010 | 11:06 AM
ur right the pistons do come up over the block dont remember how much its already disassembled so i cant measure it is this bad does it make it more likely to hit a valve???
Old Sep 25, 2010 | 11:11 AM
fv8s's Avatar
what do you mean its the same block? the b16b has a way shorter stroke than the GsR/ITR block. almost a 10mm difference (same bore size though)
Old Sep 25, 2010 | 04:15 PM
Deetz's Avatar
Crazy Honda Guy
What do i mean????? ALL B16B, B18C, B18C1, and B18C5 blocks are "EXACTLY" the same, and stamped P72
The B16B is way different than a B16A. The B16B is a "destroked" B18C
Old Sep 28, 2010 | 08:32 PM
yeah u are right bro i did more research and took the block to a machine shop and they are the same bore wise and they are stamped p72 so it is a 1.8L block
well sad to say but the B16b was not worth fixing so i just bought a complete long block b16a1 but i really appreciate the help and info guys hopefully i can help u guys in the future
broly12phoenix
Jul 7, 2006 09:48 PM
001020
Mar 20, 2005 06:52 PM
fastlude69
Mar 11, 2004 03:50 AM
ill_take_one
28
Feb 25, 2003 09:00 PM
Sh4rky
May 24, 2002 08:37 PM
