Is mainshaft of lsd-equipped trans same as the usdm trans without lsd?
Old Sep 24, 2010 | 02:54 PM
krick182's Avatar
Default Is mainshaft of lsd-equipped trans same as the usdm trans without lsd?
I have a JDM B16 Y21 transmission with oem lsd. Part of the housing on the diffs is fractured and I wanted to buy replacement LSD for it. Apparently the final drive ring gear on my oem lsd will not bolt up to the aftermarket LSD for the usdm trans. so what I want to know, is the mainshaft on the lsd-equipped trans the same as the usdm trans without lsd. If so, wouldn't I be able to just buy the ring gear for the usdm trans without lsd, bolt it to the aftermarket LSD(probably a quaife), and drop it in my lsd-equipped transmission?
Old Sep 24, 2010 | 02:58 PM
beeandgee2477's Avatar
Default Re: b16 Differential
what year is it,,,the cable b16s had a different spline but if it is hydro then it might be one of the special ordered 96-97 lsd trans
Old Sep 24, 2010 | 03:04 PM
krick182's Avatar
its out of a 1995 del sol VTEC, Over there it was the SIR2 w/lsd, hydro
Old Sep 24, 2010 | 03:05 PM
krick182's Avatar
same transmission code Y21
DEADLYACURACCY
Transmission & Drivetrain
Feb 4, 2015 06:59 AM
EM-One
Sep 24, 2012 08:34 PM
1320king
Jan 3, 2010 07:31 PM
ChasRX
Sep 6, 2003 08:23 PM
