92 civic cx starts but then dies
have a stock 92 civic cx it starts but 3 min after it shuts off..I have tryed a working main relay and dizzy and changed a new fuel filter still does the same thing......what could it be HEELLPPPPP PLLLEEAAASSEEE!!! thanks
It sounds like you're only idling during fast idle, which leads me to believe that you aren't getting enough air during normal idle. Check/clean your idle valves and TB. Properly set the idle, preferably using a shop manual. If you are unable to fix the problem with the above suggestions, try a compression test.
kanjozoku
26
Oct 2, 2016 03:14 PM
ntensehonda
10
Jan 14, 2004 10:15 AM
