Si: Can vtec kick in early if you don't have vtec control?
wel i was wondering in my si it sounds like vtec kicks in at lik 4000-4500 rpm amd it dont have vtec control so im just wondering if i just think im hearing it or there something on it to make it do that
Si: can vtec kick in early if you don't have vtec control.
what do you mean you dont have vtec control? stock si wiring harness and stock motor? and stock ecu? then it should work...
Re: Si: can vtec kick in early if you don't have vtec control.
ur ecu might have been tampered with at some point (by that i mean adjusted to that rpm) by a previous owner.
vtec engages at 5800 rpm. what you hear at 4000 rpm is the secondary lobe on the camshaft. its bigger than the primary so it seems louder. then the vtec lobe is the biggest and is set at 5800 rpm on the stock pcm.
Re: Si: Can vtec kick in early if you don't have vtec control?
Are you still getting a loud crossover at 5700 rpm? Are you sure you have the correct ecu?
volcomborder16
Honda Civic (2006 - 2015)
22
12-04-2007 03:25 PM
