integra looses water
Old Sep 24, 2010 | 12:17 PM
kevinEJ's Avatar
Default integra looses water
sup h-t
my integra gsr with ls motor is loosing water..
i dont see any leaks or anything.
can it be burning cause i got no heater core(thats what a friend told me )
i have to refill it like half a quart every day.
NEED HELP FAST!
Old Sep 24, 2010 | 01:15 PM
Drive 4 fun's Avatar
Default Re: integra looses water
Head gasket, exhaust color, oil color and clarity, can you smell antifreeze under the hood? I think that no heater core means that you will not have a heater core leak, and not much else. If it leaks under the hood and evaporates or blows away, you will usually still smell it.
Old Nov 2, 2010 | 04:18 PM
kevinEJ's Avatar
my car is always on cold to.. it idles high at cold start around 2k rpm but wen warm its aidle at around 1k. my exhaust smell like coolant and has smoke but i check the oil it doesnt seem milky or watery.. can it be my thermostat.
thanks
Old Nov 2, 2010 | 04:28 PM
hbcrazy88's Avatar
check your thurmo for the fact that your car doesnt warm up.... but you have to have a leak somewhere or yea you have a blown head gasket. you can smell your exhuast and if it smells like coolant then do a compression test.
Old Nov 2, 2010 | 04:30 PM
Targa250R's Avatar
be professional
That doesn't necessarily mean that the head gasket is good.
I'd suggest performing both a pressure test and a combustion leak test on the cooling system.
Old Nov 2, 2010 | 10:27 PM
kevinEJ's Avatar
were can i get a leak test does autozone have it?
Old Nov 2, 2010 | 10:28 PM
kevinEJ's Avatar
also i meant the thermostat doesnt move it only moves up wen i dont put water in and i guess its about 2 over heat but after i put water its always on cold
Old Nov 2, 2010 | 10:39 PM
el crapitan's Avatar
compression test.
si-ej1
Nov 2, 2011 06:16 PM
lilshady6796
15
Jan 13, 2009 05:40 PM
Racermech
Jan 19, 2007 07:30 AM
tek_civic
Feb 16, 2006 06:43 PM
lavo81
Aug 8, 2005 12:05 PM
