Si: Can vtec kick in early if you don't have vtec control?
Old Sep 23, 2010 | 08:42 PM
2000em1boycivic's Avatar
Default Si: Can vtec kick in early if you don't have vtec control?
wel i was wondering in my si it sounds like vtec kicks in at lik 4000-4500 rpm amd it dont have vtec control so im just wondering if i just think im hearing it or there something on it to make it do that
Old Sep 23, 2010 | 08:59 PM
andrewk's Avatar
Default Si: can vtec kick in early if you don't have vtec control.
what do you mean you dont have vtec control? stock si wiring harness and stock motor? and stock ecu? then it should work...
Old Sep 23, 2010 | 09:14 PM
Default Re: Si: can vtec kick in early if you don't have vtec control.
o it work I'm just saying it sound like it kicks in early
Old Sep 23, 2010 | 11:46 PM
virgineg6's Avatar
ur ecu might have been tampered with at some point (by that i mean adjusted to that rpm) by a previous owner.
Old Sep 24, 2010 | 01:18 AM
forcefedferio's Avatar
it's possible your tach is off, however off by that much i don't know.
Old Sep 24, 2010 | 02:55 AM
JasonYo's Avatar
Vtec engages at like 6500rpm. Your tach or something is off.
Old Sep 24, 2010 | 03:18 AM
skaternak's Avatar
vtec engages at 5800 rpm. what you hear at 4000 rpm is the secondary lobe on the camshaft. its bigger than the primary so it seems louder. then the vtec lobe is the biggest and is set at 5800 rpm on the stock pcm.
Old Sep 24, 2010 | 06:29 AM
devney's Avatar
Default Re: Si: Can vtec kick in early if you don't have vtec control?
Are you still getting a loud crossover at 5700 rpm? Are you sure you have the correct ecu?
Old Sep 24, 2010 | 06:36 AM
Ryanchu2's Avatar
thanks for that one
Old Sep 24, 2010 | 02:38 PM
yeah im still geting a loud cross over and im not sure i never messed with it
Old Sep 24, 2010 | 03:19 PM
munchies91crx's Avatar
what motor. my z6 kicked in at about 4500-4800 on a non chipped p28
Old Sep 24, 2010 | 04:06 PM
I got a B16a2
Old Sep 24, 2010 | 04:40 PM
noodels's Avatar
mine is @4400 rpm standard?thought my iabs came in @5750. only on <bc4 not b16a2>
Old Sep 24, 2010 | 04:54 PM
noodels's Avatar
well clamped iabs, in open position now <forgot to mention>and comes <on cam> @5750rpm
fryman
Sep 28, 2008 02:32 PM
theVTEClife
Honda Civic (2001 - 2005)
May 20, 2008 05:03 PM
volcomborder16
Honda Civic (2006 - 2015)
22
Dec 4, 2007 03:25 PM
jfrase06
Apr 12, 2007 01:48 AM
