Rear demister switch.
Old Sep 23, 2010 | 08:13 PM
Bludger's Avatar
Default Rear demister switch.
Originally Posted by Bludger
My honda has a demister switch with a push on/push off configuration.
I have in my possession the same switch and for the same car, but only its a momentary push on configuration. On other cars with this type switch, the demister turns on when you push the button and turns off when you push it again OR after a said period of time.
What do i need (any additional hardware) to run the second switch that is mentioned....
thanks in advance.
Old Sep 23, 2010 | 08:24 PM
BlueIntegraBoy's Avatar
Default Re: Rear demister switch.
I think your switch is broken where it is not 'clicking' when you push it. Try to get another switch.
Old Sep 23, 2010 | 08:29 PM
Bludger's Avatar
I will open it up to confirm and report back.
you're sure that it doesn't exist?
Old Sep 23, 2010 | 08:32 PM
Mine engages and stays depressed.
Old Sep 23, 2010 | 08:38 PM
Bludger's Avatar
yes my friend, mine does also.
but i'm saying i have a second switch that's momentary on config.
Old Sep 24, 2010 | 11:12 AM
94rs-turbo's Avatar
your talking about the rear defroster right?
Old Sep 24, 2010 | 04:02 PM
Bludger's Avatar
demister, defroster, same thing
Old Sep 26, 2010 | 07:57 AM
Just a n00b's Avatar
Accident Prone
What do you mean by "momentary?" You push it and it's on and then goes off soon thereafter, without you pushing it again or before the timer runs out?
If this is the case, the switch may be bad as Blue says.
Alexie
Sep 30, 2018 12:16 PM
crvpilot
Feb 26, 2018 06:55 AM
DC2*Integra
Audio / Security / Video
Apr 6, 2010 08:28 AM
SR20 Inside
Jan 25, 2006 09:24 PM
