ITR SWAP SMOKING WHEN FLOORED
Old Sep 23, 2010 | 05:48 PM
TUR3Ovtec's Avatar
Default ITR SWAP SMOKING WHEN FLOORED
Hey, SO i got a ITR swapped EK and for some reason when driving normal there is no smoke at all but the minute you floor it it looks like a turbo diesel truck. Any ideas on why it does that? Car specs:
99 B18C JDM Type R
Chipped P28 by Phearable.net w/ Jumper Harness
Apexi World Sports II Exhaust w/ Skunk 2 testpipe
AEM intake
NEW fuel filter, spark plugs, cap and rotor
Old Sep 23, 2010 | 06:01 PM
The Survivor's Avatar
Default Re: ITR SWAP SMOKING WHEN FLOORED
Black smoke normally means that the car is running to rich. The chipped ecu could cause that.
Old Sep 23, 2010 | 06:47 PM
TUR3Ovtec's Avatar
do you think i could use a OBD2 JDM TYPE R ECU and get rid of the jumper harness?
Old Sep 24, 2010 | 12:18 PM
TUR3Ovtec's Avatar
bump
Old Sep 24, 2010 | 12:23 PM
ej8b16a2's Avatar
WHAT COLOR IS THE SMOKE,BLUE OR BLACK?
Old Sep 24, 2010 | 01:44 PM
-__-'s Avatar
yup can do.
Old Sep 26, 2010 | 01:00 PM
TUR3Ovtec's Avatar
when my friend was driving behind me he said it was like a blakish grey color.... and no check engine lights will come on if i use a OBD2 computer????
Old Sep 26, 2010 | 01:55 PM
decko's Avatar
why would a check engine light come on if you use the ecu that was made for the motor...?
Old Sep 26, 2010 | 04:38 PM
-__-'s Avatar
^^lol yeah try the type-r ECU and see what happens. Your "chipped ECU" may not be tuned for your setup.
Old Sep 26, 2010 | 04:44 PM
TUR3Ovtec's Avatar
yeah... true... i was thinking about what might or might not be connected to the motor right now... but its about the same price as a tune for the computer... which one would u rather do???? I want to eliminate smoke all together... get it running good...
Old Sep 26, 2010 | 04:49 PM
element600rr's Avatar
before i went spending anymore money id do a leak down and compression test .
cover your bases before you jump to any conclusion . usually base maps do run very rich but id check compression and leak down before i bought an ecu just to make sure that the tune is the issue ..
EJeff8's Avatar
^Run the ECU that matches your engine. You can never go wrong.
Old Sep 26, 2010 | 04:53 PM
decko's Avatar
all b series vtec motors smoke a little @ higher rpms
Old Sep 26, 2010 | 04:54 PM
-__-'s Avatar
grab the type-r ECU and if it fixes ur problems, sell ur Chipped P28 and jumper harness for more lol idk. up to u. you're lucky u got a friggin JDM Integra Type-R motor anyway :D
WillMuniz83
Apr 26, 2019 08:23 AM
creepy116
Nov 30, 2007 11:24 AM
bluesaint
Feb 27, 2003 12:16 PM
JDM CRX
Mar 27, 2002 10:00 AM
JKim0901
Dec 25, 2001 11:48 AM
