Honda CR-V & Element 2WD & 4WD Element & CR-V
B18b1 into a CRV?? is it possible
Old Sep 23, 2010 | 04:13 PM
b18c1ebpsol's Avatar
Default B18b1 into a CRV?? is it possible
Ok here is the deal I have a 2000 crv with 290k miles on it the motor has no compression, I know I can swap the head off a b18b1 and it works but are the blocks similiar ? if so I just want to change the whole engine to a b18b1.
Any input is great
Thanks
Old Sep 23, 2010 | 04:25 PM
94EG8's Avatar
Seagull Management
Default Re: B18b1 into a CRV?? is it possible
You can swap engines, but its going to lack a bit in terms or torque. JDM B20s are so cheap that unless you already have a B18B sitting there I wouldn't bother.
Old Sep 23, 2010 | 04:44 PM
Thats the thing I have a B18b1 in a wrecked integra now
Old Sep 23, 2010 | 08:37 PM
csingham's Avatar
crazy mad murdock
yea it wouldn't be a problem. the TQ isn't there but the car is
Old Sep 23, 2010 | 10:20 PM
daltontjh22lude's Avatar
find a ek hatch or something better
Old Sep 24, 2010 | 10:01 AM
qwrty's Avatar
Any input is great
Thanks
if the block is still good...(pistons/rods..etc) just swap the head, imo...
thats a common problem for crvs, most of the owners dont bother or no one
tells them to get valve adjustments as a part of maintenance...also a
head swap is easier than a full engine swap..!?!?
anyways, good luck!!
this i don get....
Old Sep 24, 2010 | 10:49 AM
fast2camciv's Avatar
depending on what year the engine is, you might have to do some wiring....but shouldnt be a big deal. obd2 engines are slightly different than obd1 engines. other than that, its a direct replacement.
Old Sep 24, 2010 | 11:54 AM
Stealth Si's Avatar
I put a B16 in a crv. LOL
It can be done
MattSaults
Jun 25, 2015 03:30 AM
MattSaults
Jun 24, 2015 09:29 PM
MattSaults
Jun 23, 2015 06:30 PM
Davey12678
May 13, 2010 08:27 AM
