Code 9.. No. 1 cylinder position?
Old Sep 19, 2002 | 12:30 AM
[626]95-GSR's Avatar
Default Code 9.. No. 1 cylinder position?
Tonight i was doing a little run for fun with my buddy (Tooqwik1) against his hybrid hatch. Usually i dont push my car too hard, but i have to work extra hard against those pesky hybrids.. So i was shifting at 7800-8000.. boom i see the Check engine light flash on.. check the code, 9 flashes.. and 1 flash indicating an O2 sensor problem. 9 flashes for the No. 1 cylinder position..
Im always having this problem.. i replace the distributor and it goes away.. but ive been through 4 distributors.. how can i fix this??
Old Sep 19, 2002 | 12:27 PM
tooqwik1's Avatar
Default Re: Code 9.. No. 1 cylinder position? ([626]Rj-SiHatchy)
sorrry mann i tried to take it easy on u
ill chek wit my dad to see what he says
Old Sep 19, 2002 | 06:37 PM
metric's Avatar
Default Re: Code 9.. No. 1 cylinder position? (tooqwik1)
take off your dist cap carefully and look and see if there are bits of wire in the cap.
if there is the sensor went bad. I've seen this many times and had it happen personaly a couple of times. You will have to replaced the dist.
Old Sep 19, 2002 | 08:06 PM
boostinb18's Avatar
Default Re: Code 9.. No. 1 cylinder position? (2.0CR-XVTEC)
when i had a cylinder 1 position code my am timing was off a tooth.........id check your cam timing.....good luck!
Old Sep 19, 2002 | 09:26 PM
JDM88EF9's Avatar
lol
boostng r
Oct 26, 2004 11:49 AM
TyPe-R6
Jun 18, 2003 03:41 AM
RaIn
Apr 20, 2003 08:05 PM
djtony5
Feb 4, 2003 06:10 PM
[626]95-GSR
Sep 19, 2002 11:56 AM
