What would happen if I used a P28 ECU with my 97 Civic DX/d16y8?
Old Sep 23, 2010 | 02:11 PM
ej6kid's Avatar
Default What would happen if I used a P28 ECU with my 97 Civic DX/d16y8?
i gota 97 civic dx with a d16y8 in it with a p2e ecu. what would be the outcome if i put in a p28 ecu?
Old Sep 23, 2010 | 02:14 PM
speedooo's Avatar
Default Re: d16y8 ecu question NOOB
it would not run correctly. its the wrong ecu.
Old Sep 23, 2010 | 02:15 PM
ej6kid's Avatar
Also would i run vtec if i hooked up the jumper harness?
Old Sep 23, 2010 | 02:49 PM
ej6kid's Avatar
Oure saying the p2e is the wrong one? And p28 would run better. And what bout the jumper harness?
Old Sep 23, 2010 | 02:55 PM
ej6kid's Avatar
Default Re: What would happen if I used a P28 ECU with my 97 Civic DX/d16y8?
Nvm misread that. I thought p28 was the stock ecu for my engine though
Old Sep 23, 2010 | 02:57 PM
Former User's Avatar
I believe that the P2P ECU is the correct OBD2 ECU for the D16Y8.
Old Sep 23, 2010 | 04:09 PM
ej6kid's Avatar
p2p is the auto ecu
Old Sep 23, 2010 | 04:17 PM
Originally Posted by ej6kid
p2p is the auto ecu
I don't believe so. It should come in both auto and manual versions:
http://www.hondata.com/techecuid.html
Old Sep 23, 2010 | 04:32 PM
94EG8's Avatar
Seagull Management
p2p is the auto ecu
No, they came in automatic and manual versions
Correct.
Any to anyone that wonders why a P28 wont run Y8 properly it has to do with differences in ignition timing between the Z6 and Y8.
Old Sep 23, 2010 | 06:36 PM
ej6kid's Avatar
Ok thanks yeah i got it withthe car when i bought it. Didnt know if it was a change or anything
Old Sep 23, 2010 | 06:40 PM
ej6kid's Avatar
What about the jumper harness? Whats the info onthat
Old Sep 23, 2010 | 07:05 PM
roadsqueegy95's Avatar
get a ob2a-obd1 jumper harness. It will run, but not sure how good. Not sure if you would needa tune or not.
Old Sep 23, 2010 | 07:21 PM
ej6kid's Avatar
I have one ill post pics tomorrow ill call my local shop and ask
Old Sep 23, 2010 | 07:24 PM
1994jdmej1's Avatar
well i should run good with no problems thats what i have in my car with same motor no problems so far
Old Sep 23, 2010 | 07:45 PM
ej6kid's Avatar
You have a p28 ecu in ur d16y8?
Old Sep 23, 2010 | 07:49 PM
94EG8's Avatar
Seagull Management
I'd kind of forgot about this, but there is an OBD2 P28 used with Y8s, its found only in the '96 - '97 Del Sol Si and I believe its just a P2P with a different part number.
Old Sep 23, 2010 | 07:53 PM
ej6kid's Avatar
Ill post pics of it all timorrow and you guys can let me know whats up
Old Sep 24, 2010 | 10:29 AM
ej6kid's Avatar
In my car now:
what would happen if i put this in there: even the jumper harness would i run vtec?
Old Sep 24, 2010 | 02:16 PM
94EG8's Avatar
Seagull Management
You can run the engine with the P28 with a jumper harness assuming the car is a 5 speed, if its an automatic it wont control the transmission. It will run poorly due to timing differences between the Z6 and Y8, the only way it will ever run right is if you get it chipped and tuned.
Old Sep 24, 2010 | 04:10 PM
92lxsleeper's Avatar
i wouldn't if you are in a state that does a ecu check on 96+ vehicles. OBD II.
lots of states do it now, just to plug it in and check codes. if its a p28, they can't plug it in, then it wont pass.
cali = no go with no way around it.
Old Sep 24, 2010 | 04:14 PM
batallic's Avatar
the p28 is stock for the d16z6
Old Sep 24, 2010 | 08:26 PM
ej6kid's Avatar
Yeah its a 5 speed ill hook it up see what goes on. Is it smart to run a chipped ecu on a stock engine? I live in pa i dont think its a big deal. Ill find out
Prentice916
Jul 31, 2017 10:02 AM
Alcura321
Mar 29, 2015 07:20 PM
ngarover
Mar 6, 2015 03:54 PM
Donkeylips87
Sep 25, 2010 03:49 PM
madsci
11
Mar 10, 2010 08:45 PM
