98 civic DX/ b16a2 swap/stock harness/tuned OBD1 ECU - runs poorly (video)
Old Sep 23, 2010 | 02:06 PM
beserious24's Avatar
Default 98 civic DX/ b16a2 swap/stock harness/tuned OBD1 ECU - runs poorly (video)
Alright so I got the swap in and when I went to run the car, it ran like this. You may have to turn the speakers up, its not the best quality, but let me know if this tells you anything. I can rev and keep the car running as long as I do, but the car sounds rough, and without rev'n it will just stall out.
Old Sep 23, 2010 | 03:21 PM
Former User's Avatar
Default Re: b16a2 swap not running...? (video)
Did the CEL remain on? If so, pull the CEL codes -- see CEL sticky at the top.
What car, ECU, and engine harness?
Old Sep 23, 2010 | 04:28 PM
Default Re: b16a2 swap runs poorly (video)
The car is a 98 civic DX stock harness with an OBD1 converted ECU tuned for this engine
Old Sep 23, 2010 | 04:29 PM
Any CEL codes?
Old Sep 23, 2010 | 04:32 PM
I'll have to read that and run it. I was just seeing if anyone recognized the issue easily.
Had someone on another forums tell me its probably just the tps and map sensors reversed, so I'll check that first I guess.
Old Sep 23, 2010 | 04:35 PM
Post the wire colors for each connector.
And avoid guessing --> Pull the CEL codes first.
Old Sep 23, 2010 | 04:49 PM
Default Re: 98 civic DX/ b16a2 swap/stock harness/tuned OBD1 ECU - runs poorly (video)
Ok so the car threw 10 and 21. Both of which would make sense I guess. I don't have vtec wired in yet, and I can imagine the TPS would throw if the two were switched, but I don't get why it didn't throw a code for the MAP
Old Sep 23, 2010 | 04:54 PM
Nevermind, 10 is intake air temperature sensor. I have that connected, but just pretty much sitting there. Its not in track of my intake. You think that alone would make the car run that rough?
Old Sep 23, 2010 | 05:07 PM
Everything I'm reading about the code leads me to think that the car would still run fine with it throwing that code. So I don't think thats whats making the car run like that.
Old Sep 23, 2010 | 05:12 PM
Post the wire colors for the TPS and MAP sensor. Swapping connectors does not always throw CEL codes.
Is the IAT sensor plugged in? What color wires are in its connector?
Also check the plugs, wires, cap, and rotor.
Did you already check the mechanical timing?
Old Sep 23, 2010 | 05:15 PM
Mot Gnuoy's Avatar
Sounds like a vacuum leak. possibly the vacuum line from the intake manifold to the brake booster.
Old Sep 23, 2010 | 05:26 PM
yellow/red, green/white and green/red for the TPS plug.
yellow/blue, green/black, and red/black for the MAP
The timing, rotor, plugs, wires and caps are good though.
For the IAT, those wires colors are, black/blue, orange, and yellow or white with black.
Old Sep 23, 2010 | 05:52 PM
Your TPS and MAP sensor connectors are indeed swapped.
Old Sep 23, 2010 | 05:53 PM
This is the IACV connector not the IAT connector.
Old Sep 23, 2010 | 05:55 PM
For what its worth, it seems like the TPS and MAP couldn't swap. The way its loomed, its real close with the injector plugs and stuff. Is it normal to have to maybe cut back the looming to make it reach
Old Sep 23, 2010 | 05:57 PM
The wire colors in the connectors definitively say that your MAP sensor and TPS connectors are switched.
And the three wire IAT connector is actually the IACV connector. The IAT sensor connector only has two wires.
Old Sep 23, 2010 | 06:54 PM
I guess I'll have to cut back the loom then.
Old Sep 24, 2010 | 07:42 AM
I'll keep it updated once I try swapping the tps and map. I don't think it is any vacuum leak however
Old Sep 25, 2010 | 05:18 PM
Tps and map switched...video coming up
impr323
Oct 5, 2012 09:08 PM
No
May 13, 2005 02:49 PM
aaronblake98
Feb 26, 2004 10:30 PM
2dark2bslow
Jan 27, 2004 02:15 PM
