EK with B18C swap - What replacement axles do I buy?
First of all, Hi everyone. Im a new member here, finally back in a Honda after a very long time. Just bought a EK with B18C swap.
Here my problem. I need to replace my driver side axle. But i have no idea what to get. I dont know what the previous owner put on and i cant tell what they are. Is there an easy way to identify them? Or if i change both, what should i get. From my research i found that 94+ Teg axle would work, is that correct?
Thanks for the help,
Fred
Fred
Thread titles MUST be subject specific so that members browsing topics can easily understand the tech problem without reading the post:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Because you are a new member, I edited the title for you this time.
94-01 integra, 94-97 del sol vtec, 99-00 si...
I'd recommend sticking with si axles so the people at the counter dont get confused/upset
So any of these will work? Integra should be easier to find around here. Does it matter which model of Teg or they're all the same. Thanks for the help guys!
https://honda-tech.com/forums/showthread.php?t=2809571
Pull the axle. If the inner joint has a male end you need an axle from a '90 - '93 Integra, any model. If it has a female end you need an axle from a '94 - '01 Integra/'94 - '97 Del Sol Vtec/'99 - '00 Si
also if it is a 90-93 integra axle, then that means your half shaft is also a 90-93 integra. So if you want 94+ integra axles instead, Just replace the 90-93 integra half shaft with a 94+ integra half shaft
This ^ New halfshaft is like $400+ Used probably $100+ and its completely unnecessary, theres nothing wrong with running a '90 - '93 axle and halfshaft, its just different, no better or worse.
