what position is your distributor in stock form??
Old Sep 23, 2010 | 01:06 AM
cilvia's Avatar
Default what position is your distributor in stock form??
real noob question i kno but im wondering if everyone with a d16y8 has their distributor positioned dead center and points 12* on the crank?? reason why im asking is cause i got a chipped p28 with a basemap where im not sure what my idle regions are set too so cant really check the timing for trueness, so i want to see if it is normally dead centered so i can position mines there and have my tuner start from there...thanks
Old Sep 23, 2010 | 06:54 AM
Former User's Avatar
Default Re: what position is your distributor in stock form??
I don't think that the distributor is necessarily dead center when the ignition timing is set to spec. Have you tried to set the idle to spec using the idle adjustment screw so that you can time the engine with a timing gun?
Old Sep 23, 2010 | 08:27 AM
cilvia's Avatar
The thing is that i dont kno where my idle region is set to on my ecu so i wont be able to adjust accordingly
Old Sep 23, 2010 | 08:52 AM
You may be able to override the ECU setting with the idle screw on the TB or disconnecting the IACV plug.
Gator417
Aug 19, 2015 08:41 AM
trevek10
May 16, 2011 03:07 PM
shadohconspiracy
Apr 20, 2008 04:21 PM
924doorEG
Sep 27, 2007 03:06 PM
ludedudesi
Feb 9, 2003 03:09 PM
