gsr motor build
Old Sep 22, 2010 | 06:39 PM
ej2ndc5's Avatar
Default gsr motor build
wondering if i should use:
-an LS crank and rods
-or my gsr crank and rods
also thinking about:
-jdm p30 pistons
or
-jdm itr pitons
help me out. thanks
eventually the head is gonna be equipped with cams and valve train. but want to know more on my bottom end build
Old Sep 22, 2010 | 08:07 PM
raverx3m's Avatar
Default Re: gsr motor build
whats the full package?
you need to know what the complete package will be before picking parts like this.
the cylinder bore
how much compression you are planning on/how much CR your cams need
how high your redline gonna be
what cams you are planning to use
valves(oversized/flat faced/stock)
springs retainers stock/ aftermarket matching the cams you pick
headwork(ported,valve angle job?)
what intake manifold you planning to use.
is it gonna be turbo/NA nitrous?
this is your first post and its not enough information for anyone to give you a correct answer.
Old Sep 22, 2010 | 08:15 PM
raverx3m's Avatar
check out the following links to give you a better idea, take a week off before asking questions and read thru the forums thats what i did. after i was done i ended up with 1000s more questions lol but i had a better idea about what i want to do
dyno thread see what packages make what numbers( pay attention to the dyno curve as well, where it makes power)
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/official-all-motor-dyno-thread-1583606/
evans tuning dyno section is where i started myself
alot of great dynos to compare check out turbo section as well, just dont get sold on turbo i almost did
http://forums.evans-tuning.com/viewforum.php?f=39
http://forums.evans-tuning.com/viewtopic.php?f=15&t=41
my build thread and there are many more like this please search for them as well
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/gsr-build-questions-about-clearances-power-cams-2794034/
Old Sep 23, 2010 | 12:48 AM
ej2ndc5's Avatar
my cylinder bore is gonna be stock so 81mm
i was thinking rs machines itr pistons, oem itrs or p30s (not too sure)
LS crank and rods for longer stroke
i have a jdm p73 ecu on the side
as for head work, its gonna be stock. i think its gonna consist more of oem ctr/itr cams, valves, retainers and all that stuff
no port and polish.
edelbrock victor x intake manifold
itr header (????)
gsr tranny
apexi ws2 exhaust
going for a mild n/a build
Old Sep 23, 2010 | 01:29 AM
RareSpirits's Avatar
All of that sounds good except for LS rods & victor X. If you don't have those items don't bother to buy. P30/itr pistons will be a good setup. Itr header also is fine. All the fancy valve springs and retainers are useless unless your going to shoot for more performance down the road (ex FI ). You can buy a used set of itr exh springs to make your exhaust side dual at a fraction of the cost.
I hope I helped, if not others with more exp. Can chime in to help you out.
Old Sep 23, 2010 | 08:57 AM
ej2ndc5's Avatar
thanks for the help guys.but why isnt the victor x manifold good?
Old Sep 23, 2010 | 09:56 AM
PyroProblem's Avatar
The victor X is a huge manifold designed for larger displacement and high revs. On your particular setup, the performer X or even maybe the oem gsr manifold would be a better choice.
The victor X would probably only make more power at like 8k rpms and up. Focus on making usable power between 5k to your redline.
93gsr4dr
Mar 3, 2012 06:09 PM
fatpride111
27
Jun 26, 2008 05:23 PM
grundle
Apr 17, 2008 05:13 AM
moto1320
Mar 4, 2005 10:05 PM
WHITE DEATH
Oct 6, 2004 05:32 AM
