Ef9 back fire?
Old Sep 22, 2010 | 01:47 PM
JDM C.A.R's Avatar
Default Ef9 back fire?
So I don't know if u have read the last post I Did about someone adding sugar to the gas tank. So here it goes I was at mcds and the at started to heat up alittle once I left everything was good but out of no where I put it in first gear and the car would like run and would just trow a big fart luckely my wife saw when I did that and she said it was fire that came out the exhaust. This is my brothers car and it's jut parked in my garage what do u guys suggest I should do. We don't want to make things worse by driving it
Old Sep 22, 2010 | 02:43 PM
.Manny.'s Avatar
Touching My Member
Default Re: Ef9 back fire?
shooting fire out of exhaust > drive-ability
Old Sep 22, 2010 | 03:33 PM
JDM C.A.R's Avatar
Yeah it wouldn't run. how should I explain it.well it would run a little but with force like if something was stuck on the exhaust and couldn't get out and when it did it was fire
Old Sep 22, 2010 | 05:24 PM
Oedwards's Avatar
I would check the cam timing, If it's an old belt it could have slipped.
Old Sep 22, 2010 | 08:21 PM
JDM C.A.R's Avatar
Ok but so u think the sugar **** doesn't effect anything
Old Sep 22, 2010 | 08:46 PM
.Manny.'s Avatar
Touching My Member
I would drain the tank for peace of mind. never hurts to check it out. no cel?
Old Sep 22, 2010 | 09:06 PM
JDM C.A.R's Avatar
it has a cel but it has nothing to do with that. i had a question about it because im not sure if i might need it or not whitch i will post tomorrow morning with picture. but i guess draining the tank wouldnt be a bad idea.
Old Sep 26, 2010 | 11:19 PM
JDM C.A.R's Avatar
so i checked the codes for cel cause the light came on it was code 4 (Crankshaft Position Sensor) and 7 (cyp sensor) what should i do just get a new distributor or what do u guys suggest i should do
Old Sep 27, 2010 | 11:00 AM
Fo-Do Fanatic's Avatar
Don't guess with a "solution". Trouble shoot.
Just drain the tank and go from there.
Old Sep 27, 2010 | 12:30 PM
JDM C.A.R's Avatar
im to start doing that tonigh since i have time and im off work tomorrow im also hitting the junkyard need some parts.
Phr33l
Mar 14, 2012 02:30 PM
DA_DRE
Welding / Fabrication
27
Apr 4, 2008 03:08 PM
Teglessb18
Oct 3, 2007 08:53 PM
Thunder Cat
Feb 10, 2006 10:05 PM
Odiedogcx
Dec 27, 2003 11:27 AM
