obd1 vs obd2 distributor?
Old Sep 22, 2010 | 01:18 PM
89civicsiowner's Avatar
Default obd1 vs obd2 distributor?
so i broke my ignition rotor and a friend gave me a working obd2 dizzy seems to me there is one less plug can i still use this dizzy? what kind of conversion can i do?
Old Sep 22, 2010 | 01:43 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: obd1 vs obd2 distributor?
It depends on which distributor you had and which one you got. The main difference between OBD1 and OBD2 distributors is that the newer one has all the same wires but contained into one plug instead of two plugs. The other difference is VTEC vs non VTEC, one of the internal sensors is slightly different.
Old Sep 22, 2010 | 01:56 PM
wait so you have to use a vtec dizzy with a vtec motor? cant mix and match?
Old Sep 22, 2010 | 02:06 PM
Deetz's Avatar
Crazy Honda Guy
The legs of the dizzy housing are different so it doesn't mount proper, that is why. Some people do cheesy things and cut a leg or two off with it only partially mounted
As far as OBDI and OBDII dizzy's go, they are the same internally. As already mentioned, obdI has two plugs, obdII has a single larger plug, but the wires are exactly the same, even color for color
Old Sep 22, 2010 | 02:07 PM
24TEN's Avatar
PHANTOM MENACE
I've heard people say you can mix and match but I've also come across a thread (on another forum) that had shown the internal difference between the VTEC and non VTEC distributor. If you mix and match, I believe the car will run but you'll have a CEL because of that one sensor. I think the physical piece is 180 degrees out on the internal shaft and the thread did show a way to correct it. Technically I guess the sensor is the same it just picks up the signal differently because that one piece is 180 degrees off.
EDIT: and Deetz did bring up a good point. Z6 dizzy only fits the Z6 head properly unless you run it on two bolts or chop off a leg...
EDIT2: here's the thread in case anyone wants to get educated
http://www.d-series.org/forums/gener...th-busted.html
Old Sep 22, 2010 | 02:26 PM
i just swapped the guts since i last posted and it works fine thanks though!
Old Sep 22, 2010 | 04:38 PM
wierd part is i got a dizzy off of a y7 i think and it looked just like the one i have internaly but with one less connector, the cyp was identical and i marked everything so it went back together the same way it came apart but it still seems not to be timed right any ideas?
Old Sep 22, 2010 | 04:44 PM
D16SiHatch's Avatar
dunno if there is a difference for b-series distributors but their appears to be for d
if you read through the whole thread you'll see they still don't fully agree on the difference really meaning anything because it seems some people are running non-vtec d-series dizzy's on vtec engines, and vice versa. so i dunno what to think
Old Sep 22, 2010 | 04:47 PM
hmmm but my car wont run at all seems the timing is way off but cant figure out where, swapped the key on the dizzy 180 and still nothing, plug wires are right on spark at every plug and it still idles like a sick harley or not at all is there a way to screw up the timing in the dizzy im not aware of?
IVI
Jul 10, 2006 01:20 PM
HamiltonRex
Mar 22, 2005 07:53 AM
pootie.teng
Feb 25, 2004 12:48 PM
Street Ghost
Jun 10, 2003 02:08 PM
mugenDAxsi
Jan 31, 2003 11:22 AM
