94 civic ex code 14 need advice
I am just curious as to what I should start to check to aleiveate this issue it'll buck a little over idle if u give it a little gas out of gear the Rpms will bounce. I tried unplugging the iacv no change the car performs really well out on the highway it's just in town which is aggravating any help would be appreciated and the car does idle fine
Motor is a jdm b18c
Motor is a jdm b18c
I just cleaned the iacv the motor has no fitv on the throttle body I just order a new throttle body gasket from Honda I'll check that throttle cable too
Thanks
Thanks
Is the throttle body dirty? Have you tried to adjust the idle speed by the procedure described in the service manual?
Have you checked output voltage of the TPS and resistance of the ECT sensor when the engine is warmed up?
I just checked the tps reading .50 closed and
4.5 wot...
The coolant temp sensor is the one on the side of the head with 2 wires running to it right just wanna be sure I checked the right one...
4.5 wot...
Yep that was it also noticed the idle screw was screwed out most of the way adjusted it down it no longer fluctuates but the cel is still on and I have no VTEC engagement now lol (guess they they where to lazy to try to figure out the problem)
Will be replacing the coolant temp sensor next hopefully this take care of the problem also noticed some black soot on my back bumper mustve been running a bit rich due to that I guess
Replaced coolant temp sensor no change....
I notice that idle is not higher when I cold start it....maybe the iacv is bad I dunno
What else can I try
Also car does not have a fitv on it
What else can I try
supracrx
Jan 7, 2007 08:06 PM
