95 Civic DX - Code 4 Crank position sensor????
Old Sep 21, 2010 | 07:10 AM
Bakuryu06's Avatar
Default 95 Civic DX - Code 4 Crank position sensor????
Hi guys, I have a 95 Civic DX with a stock D15B7. The car is in immaculate condition from inside out. The engine is super clean with the exception of one big problem:
Idle/Turning off problems. As I slow down the car shuts off at random intervals as I put the car in Neutral. Basically it cuts off and I have to do a rolling kick start or stop the car and restart in that case, it fires up.While its turned off I can jump-start the car by putting it in gear and hitting the gas pedal, pretty much a classic rolling start. That is when the check engine light comes on. First thought was fuel injectors and I got them cleaned yet still the same issue. I just had a new timing belt and water pump installed as the car is at 94k. New distributor. The previous owner had just done a tune-up which included a new distributor and spark-plugs. What should I check first? Distributor?
Checked the engine code finally and am Getting
CODE: 04 - Code 4 Crank position sensor . TO my knowledge this car shouldn't have one irght????
CODE: 02 - OXYGEN Content B -
Old Sep 21, 2010 | 07:48 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: 95 Civic DX - Code 4 Crank position sensor????
CODE: 04 - Code 4 Crank position sensor . TO my knowledge this car shouldn't have one right???? yes it has one. its in the dizzy. so your problem is with the dizzy. loosen the bolts and turn it. your ingition timing is wack.
CODE: 02 - OXYGEN Content B you dont need this. this 2nd o2 is to tell your your cat is clogged or you have a blown cat(emissions) ignore it or get an o2 extender bypass thing or get a chpd ecu and disable the light for it-
Old Sep 21, 2010 | 08:04 AM
Bakuryu06's Avatar
The timing doesn't seem to be off, when the car is running, there is no power loss and the car runs extremely smooth. Just idles down and dies occasionally. Still could be the distributor? I believe the fellow before me changed the distribute TO fix the idle turn off problem. Could it be the Idle Air Control Valve?
Old Sep 21, 2010 | 08:11 AM
I'm not Rick!
maybe but iacv would act up only until warm.
u have mechanical timing and ignition timing. try turning the dizzy
Old Sep 21, 2010 | 08:24 AM
Bakuryu06's Avatar
Well the car doesn't really act up until I drive around for 20minutes, sometimes it doesn't until I drive on the high way at high miles. I'll turn the dizzy tonight and see if that makes a difference.
Old Sep 21, 2010 | 08:28 AM
Former User's Avatar
For code 4, measure the resistance of the CKP sensor and check the wires for a short or open using a multimeter. If those are fine, the ECU may be bad.
My understanding is that code 2 is specifically for OBD0 4th gen Civics. Someone correct me if I'm wrong. An erroneous code can also indicate a bad ECU.
Old Sep 21, 2010 | 09:22 AM
94EG8's Avatar
Seagull Management
I assume so. OBD0 civics and integras used 2 single wire unheated O2 sensors, both in the manifold.
Tchay
18
Dec 16, 2013 08:21 AM
sitrucjr
Feb 19, 2004 07:42 PM
JDM DC2 R
Mar 13, 2003 01:19 AM
Spade
Jul 30, 2002 02:05 PM
