Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Honda Accord: How to install valve cover gasket
Step by step instructions for do-it-yourself repairs.
VALVE COVER GASKET REPLACE!!!HELP
i am wanting to replace my valve cover gasket cuz its leaking a little oil...i want to know if it is really as simple as disconnecting the battery and taking off the valve cover bolts cleaning the area the gasket goes and then slapping on the new one and tighten...is it really this simple or am i forgetting to do something?
Also, apply liquid gasket (Honda Bond or equivalent like Permatex Ultra Gray) to the corners of the humps where it goes over the camshafts.
Why would you disconnect the battery?
Just take off a couple 10mm bolts/nuts, change the gasket, and put it back on. Shouldn't take you longer than 10 minutes. If it takes longer than 10 minutes, then you've chosen the wrong hobby.
Oil leaks are tricky to trace. I hope you're right about it being the valve cover gasket. Also, having a micro torque wrench helps. I believe those nuts are supposed to be torqued to 8 ft-lbs.
Make sure both mating surfaces are perfectly clean and smoothe. Use honda bond in the corners.
Good luck
Good luck
If you're going to do it you may as well do it right.
On this note you should also be replacing the grommets around all 8 studs on the cover and the spark plug holes. If the grommets are flattened too much it will cause the acorn nut to bottom out on the stud and strip even when correct torque is applied. A good 1/4" drive torque wrench will be your friend here as the nuts should be sequenced down to about 90in/lb(8ft/lb). It's also been mentioned to put a dab of high temperature gasket compound in the corners surrounding the cams.
depo
Mar 23, 2019 09:37 PM
rallyeredem2
Honda Civic (2001 - 2005)
Dec 25, 2014 10:58 AM
type Gendy
10
Sep 6, 2003 10:44 AM
B18C-Hatch
May 19, 2003 02:44 PM
