1998 Civic with 79000 miles
Old Sep 20, 2010 | 12:37 PM
Rhood's Avatar
Default 1998 Civic with 79000 miles
I was told it time for a timing belt any way of seeing the condition of the belt ?
Old Sep 20, 2010 | 12:41 PM
rick_rabies's Avatar
I'm not Rick!
Default Re: 1998 Civic with 79000 miles
pull the plastic timing belt cover off the top (which is a pain)
and see if the belt is cracked by the teeth (under the belt) and see if there is slack.
cracks or slack replace it. rule of thumb will all timing belt cars is 100k change out. which no1 ever does.
sum companies say 70-80k etc to cover you.
jus put a 100 shot on it youl be fine
Old Sep 20, 2010 | 01:29 PM
94EG8's Avatar
Seagull Management
i've seen timing belts break and look pretty good except where they broke, I've also seen one that didn't break that was cracked so bad no one could figure out why it hadn't broken. If its the original belt replace it. IIRC the manual says every 100,000, or every 6 years, whichever comes first.
Old Sep 20, 2010 | 04:33 PM
RCurioso88's Avatar
i'm more safe than sorry so i would replace it if funds arent tight.
newbie2012
Oct 26, 2012 11:14 AM
msnewman
Jul 19, 2012 05:13 AM
AnAccordIsForever
Mar 12, 2007 02:55 PM
Imprezn
May 6, 2003 01:36 PM
