1997 Acura Integra LS Not Starting
Old Sep 19, 2010 | 06:23 PM
tacosandbeans's Avatar
Default 1997 Acura Integra LS Not Starting
I just dropped a 1998 Acura Integra Type R swap into my car. It has MSD blaster coil and stock engine harness. It's cranking over but not starting. It's getting spark, the fuel pump is kicking on, it's getting fuel but not shooting out of the injectors. I only have the passenger side axle in right now and no shift linkage. How come it's not turning over?
Old Sep 19, 2010 | 06:25 PM
Default Re: 1997 Acura Integra LS Not Starting
Does anyone know what color the tps and map sensor are on the engine harness, i think i might have them plugged in backwards. Would this keep it from not turning over... Also my rpms aren't moving up and down on my gauge cluster when the car is cranking over
Old Sep 19, 2010 | 06:45 PM
GREEN/WHITE
RED/YELLOW
ALL WHITE
MAP SENSOR
YELLOW/WHITE
RED/BLUE
GREEN/WHITE
TPS SENSOR
FIRING ORDER
13
24
I also have AEM cam gears
Everything correct?
Old Sep 20, 2010 | 11:03 AM
badrex38's Avatar
34 <--- plugs should be on in this order starting at bottom left
12 going clockwise 1-3-4-2
if you got spark and fuel you should be running also if the car has any kinda of backfire during cranking its most likely wrong positioning of the sparkplug wires
Old Sep 20, 2010 | 07:58 PM
fcm's Avatar
fcm
Old Fart
Check for power at the injectors, [wire that is the same color on all 4 injectors should have 12V+ on them as long as ign. switch is in run or start.
Hows the fuel pressure, how old is the fuel filter? 94
Old Sep 20, 2010 | 08:23 PM
del624's Avatar
make sure at the end of ur harness nothing is unclipped
joshd_bh
Apr 18, 2016 12:30 PM
soupE__
Jul 19, 2011 05:55 AM
tacosandbeans
Sep 20, 2010 10:44 AM
stpacura
Engine Management and Tuning
Aug 8, 2008 10:35 PM
alleyezonme
Feb 22, 2006 11:42 PM
