Replacing slave cylinder 99 accord 4cyl
Old Sep 19, 2010 | 06:06 PM
Jester88Si's Avatar
Default Replacing slave cylinder 99 accord 4cyl
I need help desperately I see lots of posts about replacing the slave cylinder but one thing boggles me how do you remove the line from the slave cylinder its self if someone can tell me that I'm set. Thank you so much! - Victor
Old Sep 19, 2010 | 06:23 PM
tamadrummer1120's Avatar
Default Re: Replacing slave cylinder 99 accord 4cyl
You mean hydraulic line going into it?
Just use a flare wrench on it with the appropriate size......
if it is real rusted up, use some loosen it and let it soak for a few minutes, then try it.
Then replace, and bleed line accordingly after wards.
Old Sep 19, 2010 | 06:29 PM
Jester88Si's Avatar
yeah the hydraulic line but its round not your standard screw on type that is what has me bummed about replacing it
Old Sep 19, 2010 | 06:30 PM
post a picture if you could.
Old Sep 19, 2010 | 06:44 PM
Jester88Si's Avatar
hard to see but the connection itself allows it to pivet and whatnot
Old Sep 19, 2010 | 07:06 PM
are you sure thats not a nut at the end of that line? looks like it from here. and it does not sound like honda to do something like that.....
Old Sep 19, 2010 | 11:53 PM
Jester88Si's Avatar
I'm positive if I could just use a wrench to take it off I would do it and not trouble myself with making this post. Anyone with a 98-02 accord know what I'm talking about????
Old Sep 22, 2010 | 07:15 AM
92civlude's Avatar
If you look closely, there is a little pin holding the line in place. You must tap the pin out with a hammer and punch. What Ive done is unbolt the slave cylinder and raise/reposition it for easier access before I take the pin out.
Old Aug 9, 2013 | 05:42 AM
m3tech95's Avatar
As I hate when threads like this are not completed & I know for a FACT future people who run into this problem will eventually land on this thread during a google search, I provided some further detail on replacing the slave cylinder & how to remove the pin.
Where the line bolts in to the slave assembly:
You need to use a 3/32 punch to remove the pin & it will release the line from the assembly:
Sorry for bumping an old thread hope this saves some people time & headache in the future
Old Apr 6, 2014 | 03:22 AM
1q2w3e4r5t6y7u8's Avatar
hi everyone sorry to bring it up again can some one please help m3tech95 I tried removing my slave cylinder, I have knocked out the pin at least I think I have I didn't notice anything com out but I can now push a pin through the hole but the piece is still stuck, it swivels but doesn't come out. and I kneed the piece to fit my new slave cylinder. Id really appreciate any help.
jasonzns
Nov 10, 2024 01:33 PM
ns-export
Oct 22, 2017 08:45 AM
westcoastaccord
Jun 24, 2016 12:34 PM
ZMan3000
May 21, 2008 11:53 AM
EGh22aEG
Jul 21, 2003 03:36 PM
