my first cage attempt...
Old Sep 19, 2010 | 08:32 AM
061000rr's Avatar
Default my first cage attempt...
hey i was just wanting to get some input on my first cage attempt. im getting ready to cage my 94 integra with a 10 point and was just seeing if there is anything im doing wrong or need to do different. i no i way over did the rear plates. i was just trying to tie in the strut towers to the floor plate.
Old Sep 19, 2010 | 10:01 AM
DB2-R81's Avatar
25 Year Member
Default Re: my first cage attempt...
Putting bends in bars reduces their strength and stiffness substantially, ie: the rear stays with bends will provide little strength in preventing the main hoop from folding to the rear. Pull the rear stays and use straight stays.
Old Sep 19, 2010 | 02:34 PM
I.C.C.'s Avatar
I like how you did the lower d bar. Did you buy that, or bend it yourself? I've been looking for one like that instead of cutting the tunnel to run a straight bar... I agree with the above poster about the rear bars, but aside from that it all looks good to me..
Old Sep 19, 2010 | 04:18 PM
woowoo16's Avatar
I think he has the rear bars bent because If they were stright they wouldnt clear the back seats.
Old Sep 19, 2010 | 04:43 PM
061000rr's Avatar
i bent it myself. somehow i did it on my first try!
Old Sep 19, 2010 | 05:12 PM
Erik95LS's Avatar
rear legs need to be straight and main hoop needs an un-interupted cross bar
Old Sep 19, 2010 | 06:14 PM
CrAzE191st's Avatar
gj for a first try
Old Sep 19, 2010 | 07:21 PM
redzcstandardhatch's Avatar
something different
drag cages love bent tubes for some reason.
Old Sep 19, 2010 | 07:24 PM
k24em2's Avatar
Originally Posted by solbrothers
rear seats in a car with a roll bar?
This
Old Sep 19, 2010 | 08:34 PM
I.C.C.'s Avatar
If you'd like to recreate that lower DBar as you did yours, I'd be more than happy to take one off your hands
Old Sep 20, 2010 | 04:43 AM
trrbl1bmx's Avatar
Looks good for first try! Is this car going to be raced in a particular sanctioned body?
Old Sep 20, 2010 | 04:49 AM
061000rr's Avatar
i can do that. do you want chromoly or mild steel?
Old Sep 20, 2010 | 06:18 AM
061000rr's Avatar
this is just my play car. i got it cheap as hell and took everything out of my integra and put in this car while i did all the work to my integra. personally i hate civic hatch's! i did the cage around the interior hoping it would be easier to sell. but i want to build the integra to run true street. thats why i was asking about this cage so when i built the new one it would be legal
Old Sep 20, 2010 | 10:01 AM
I.C.C.'s Avatar
SWEEEET!!! Mild... Just PM me how much you want + shipping etc. I'm in Tampa,FL 33612...
Thanks,
Chris
Old Sep 20, 2010 | 02:28 PM
k24em2's Avatar
Stick to proven designs unless you're qualified to design one yourself
Old Sep 20, 2010 | 03:17 PM
njn63's Avatar
Definitely don't do bent rear bars again. Designs like that legitimately scare me because the weaker rear supports may fold in a crash allowing the main hoop to fold back. When your belts are secured to that hoop.... yeah, you're not going to like the results.
If you're going to be drag racing, just follow NHRA rules when building the cage.
Old Sep 20, 2010 | 03:54 PM
Fast50racer228's Avatar
That is pretty sweet!
Old Sep 20, 2010 | 05:35 PM
weiRtech's Avatar
OG Fabricator
nhra does not specify the rear bars need to be straight. they only specify they need to go to the floor.
Old Sep 20, 2010 | 05:40 PM
061000rr's Avatar
that is what i thought. but i didnt plan to make the bars bent in my integra because it is going to be a race car so there wouldnt be any seats. i only done this because i want to sell the chassis and thought it would be easier with interior in it.
Old Sep 22, 2010 | 01:52 PM
welfarepc's Avatar
from reading the rule book it looks like the d bar needs to go across the floor and is to be welded to the rocker sill area, not the main hoop. i might be wrong, but i was planning on putting mine from rocker to rocker behind the main hoop with the d bars coming down to to the lower d bar.
Old Sep 23, 2010 | 11:44 AM
runsfromdacops's Avatar
no the d bars need to go from the harness bar to a floor bar.the cage will pass tech no problem.bent rear bars arnt the best but they are still legal.
Old Sep 24, 2010 | 09:14 AM
welfarepc's Avatar
sorry thats what i meant. does the "floor bar" have to go from rocker to rocker, or can it tie into the main hoop??
Old Sep 24, 2010 | 09:19 AM
speeddave's Avatar
i believe it can be done either way. Check out this thread, i was sent the diagram by S&W
https://honda-tech.com/forums/drag-racing-36/cage-setup-2777817/
Old Oct 3, 2010 | 09:21 PM
speeddave's Avatar
looks like it might have to go to the sill plates after all. There's a guy in the drag racing forum that just failed because his go to the main hoop.
just wanted to put this info in this thread incase anybody is using it as a reference, check with your local nhra inspector before going ahead!
Old Oct 4, 2010 | 09:48 AM
welfarepc's Avatar
^ good to know thanks for posting that up man.
