b16a valve train Tips what retainers???
Thanks for your input
I know why a B16 .. but too much pressure for a B18 or bigger
By the way the car is my DD
I have the block built ,, running 12.5 :1 Cp with eagle rods
The head is PP
I have Supertech Springs from another build
Pressure, lbs@mm --- 70 lbs @ 33.5mm
Max Net Lift -- 14.00mm
Coil Bind -- 19.50mm
Rate, lbsmm -- 10.00
I plan on running S2P2 cams
with those springs or should I get the Pro springs ?
my main question is .. I see lots of guys have prob with TI retainers
should I go with
Crower TI
Super tech TI
brian crower steel retainers
New Stock B-Series
New K20R retainer
thanks
The head is PP
should I go with
Crower TI
Super tech TI
New Stock B-Series
New K20R retainer
thanks
Swap'D Motorz
Jul 24, 2010 06:42 PM
Chillinit
11
Mar 14, 2008 04:22 AM
