I NEED HELP!!! Electrical Problem.....
Old Sep 18, 2002 | 07:10 PM
ElectronMan's Avatar
Default I NEED HELP!!! Electrical Problem.....
Tonight I finished up my head gasket swap. Got everything back together. The battery was low, so I attempted to jump it off. I let it sit for a few minutes charging. When I tryied to turn it over my friend yelled stop because where the oil line was resting against the valve cover was glowing orange. So I checked all over and didnt see anything wrong. And I checked the voltages when the starter is engaged. and there is 12+ volts between the oil line and ground.
Anyone have any sort of Idea of what it may be shorting with?
Thanks
Old Sep 18, 2002 | 07:34 PM
BreakStuff's Avatar
New User
Default Re: I NEED HELP!!! Electrical Problem..... (ElectronMan)
You have to be more specific.. I never heard of an oil line , let alone the idea of swapping a headgasket..
How exactly did you attempt to jump the car?.. were the jumper cables hooked up properly?....
Old Sep 18, 2002 | 07:53 PM
Default Re: I NEED HELP!!! Electrical Problem..... (BreakStuff)
The oil line for the turbo and I changed out the headgasket for a thicker Cometic one. Jumping is not the problem. I have a short somewhere, but I dont know where to start looking.
Old Sep 19, 2002 | 12:03 AM
B18C-EJ1
Guest
Posts: n/a
Sounds more like you forgot to hook a ground wire up.
Check all your connections from removing the head and doing the work.
LooneyX90
Apr 14, 2010 11:18 PM
P.S.I Garage
Sep 1, 2008 11:59 PM
DriveSlowHomie
May 29, 2006 05:16 PM
Racer X
Dec 1, 2002 02:34 AM
ElectronMan
Sep 19, 2002 05:18 PM
