wtf??? Keep buying ecus and they fry as soon as I install and turn key
Old Sep 18, 2010 | 03:15 PM
cricketts801's Avatar
Default wtf??? Keep buying ecus and they fry as soon as I install and turn key
ok I keep buying an ecu and it frys as soon as I install and turn key. same spot every time. has anyone else had this problem? How do I fix this. Its getting expensive. please help.
Old Sep 18, 2010 | 06:27 PM
Former User's Avatar
Default Re: wtf??? Keep buying ecus and they fry as soon as I install and turn key
Check for a shorted wire.
Old Sep 18, 2010 | 06:32 PM
Deetz's Avatar
Crazy Honda Guy
ecu's are protected by a fuse so that does not happen
Old Sep 18, 2010 | 06:54 PM
ECU both receive and provide voltage. So yes, shorts to ground can and do fry ECUs.
Old Sep 18, 2010 | 07:37 PM
lunareg's Avatar
i couldnt be certain of the problem, but one would wonder: why do you keep buying ecu's if they keep frying everytime you plug them in?
Old Sep 18, 2010 | 07:39 PM
EJeff8's Avatar
Did Confucius say this?
Old Sep 18, 2010 | 07:42 PM
lunareg's Avatar
lol might have been
Old Sep 19, 2010 | 02:58 AM
94EG8's Avatar
Seagull Management
What part of the board are you frying and does the car run? If you're frying Q31 the IAT and purge solenoid plugs are probably switched around, check a wiring diagram and see that everything is plugged in correctly.
Old Sep 19, 2010 | 06:00 AM
As 94EG has wisely pointed out, checking for swapped sensor connectors would definitely be the place to start.
alston3ptswish
Apr 23, 2012 01:07 PM
cB7KiD
Jan 18, 2008 02:40 AM
DruWO
Aug 24, 2004 08:04 AM
acman1
Mar 30, 2003 12:48 PM
TypeR 599
Jan 19, 2002 11:06 AM
