wtf??? Keep buying ecus and they fry as soon as I install and turn key
ok I keep buying an ecu and it frys as soon as I install and turn key. same spot every time. has anyone else had this problem? How do I fix this. Its getting expensive. please help.
Re: wtf??? Keep buying ecus and they fry as soon as I install and turn key
i couldnt be certain of the problem, but one would wonder: why do you keep buying ecu's if they keep frying everytime you plug them in?
Seagull Management
What part of the board are you frying and does the car run? If you're frying Q31 the IAT and purge solenoid plugs are probably switched around, check a wiring diagram and see that everything is plugged in correctly.
As 94EG has wisely pointed out, checking for swapped sensor connectors would definitely be the place to start.
acman1
03-30-2003 12:48 PM
