TDC on 96 hondA accord HELP!
Here you go budd!
Your cam gear should line up like this as shown here:
Then this little crankshaft gear is located behind the big crank pulley, so make sure you have it timed as shown here in this picture. You can see the arrow on the oil pump housing to lined up with the dimple on the gear tooth :
Then when you have the crank pulley on, make sure everything else is aligned as shown here:
thanks so much its running much better now it was like 3 teeth off .... can you help me with this tho .... it idles good when cold but once normal running temp it wants to die .... drops to 0
brimac
Nov 29, 2008 09:07 AM
RCautoworks
Mar 16, 2005 06:43 PM
