help! which springs are front? which are rear?
Old Sep 18, 2002 | 06:36 PM
juniordc2's Avatar
Default help! which springs are front? which are rear?
HELP!! can anyone tell me which springs are for the front and which are for the back? and those dampers are GAB Superstroke 4ways for ITR if anyone wants to know, and the springs are RS*R ones..
BTW: one rear shock on top where the adjust is, is totally squished and can't be turned.. is there another way to adjust maybe? you just use a screwdriver and turn at the top in a slit for the others.. but the slit is shaved and squished and I can't turn it. the other 3 are ok though.
Thanks!
[Modified by dc2gsr94, 3:37 AM 9/19/2002]
Old Sep 18, 2002 | 07:53 PM
Ibuprofen's Avatar
Default Re: help! which springs are front? which are rear? (dc2gsr94)
push down on them with your weight. the stiffer ones should be the fronts
Old Sep 18, 2002 | 08:04 PM
Ferrell's Avatar
Default Re: help! which springs are front? which are rear? (01-0531)
taller up front.....shorter in rear i believe.
Old Sep 18, 2002 | 08:44 PM
juniordc2's Avatar
Default Re: help! which springs are front? which are rear? (Ferrell)
can anyone confirm? thanks for all the responses so far
Old Sep 18, 2002 | 11:25 PM
George H's Avatar
The 2 to the left with less coils are for the rear, the ones on the right with more coils are for the front.
[Modified by KANJI, 12:28 AM 9/19/2002]
Old Sep 19, 2002 | 05:59 AM
Type Zero's Avatar
That's the other way around. I helped my friend with a suspension swap before and the stock springs are longer in rear and shorter in front. Same thing goes for the aftermarket ones that he was putting on.
Old Sep 19, 2002 | 06:15 AM
auto-x's Avatar
New User
Default Re: help! which springs are front? which are rear? (Type Zero)
the 2 taller springs are front.
Old Sep 19, 2002 | 06:17 AM
uNF$@#!'s Avatar
Default Re: help! which springs are front? which are rear? (gud boi)
lol you guys are confusing the guy. look for the spring with the flat ends. thats your front springs.
Old Sep 19, 2002 | 06:48 AM
Ibuprofen's Avatar
Default Re: help! which springs are front? which are rear? (Soup ****)
ot..does it matter which end progressive springs are installed? lets say the springs were installed where the progressive springs denser coils were positioned at the bottom while the lesser coils are on top. would this matter?
Old Sep 19, 2002 | 07:51 PM
juniordc2's Avatar
the ones on the left can be stood up flat..
vega5415
11
Mar 18, 2014 11:14 PM
Wazup
Jan 26, 2006 01:11 PM
mike9571
Suspension & Brakes
13
Dec 6, 2005 07:31 PM
juniordc2
Sep 19, 2002 06:29 PM
