Spark Plugs location on 2004 honda accord v6
On the same topic, i have less than 35k on my car. Do i need to even bother replacing them? Or is it case by case basis, after looking at the plugs for signs of significant deterioration?
I dont think at 35k you need to replace unless you are suffering some performance or mileage issues. please refer to your owners manual for service intervals
Thanks - that's good advice. I just looked at my manual for the maintenance schedule, and it's not up for replacement until 105K miles! I also had in mind to change the AT fluid, but that's also after over 100k miles.
I guess i'm not working on my car this weekend...
Your good to go for at least 2x+ what you have .
I have 80k on my 03 V6, and I haven't changed the plugs yet, but I already have some new ones so I'm itching to do it. Personally, I would not wait until 100k miles to change the transmission fluid. Use "long life iridium tipped plugs" either NGK or Denso brand plugs. You can get the NGK plugs from just about any parts store, for about $10/plug. I only use Honda ATF-Z1 in the transmission, which is only available from a Honda dealer.
Have you pulled any of plugs to see how they look in 80 k ?
Also on plugs get factory replacements, don't try an go cheaper with something like Bosh Platinum , had bad experiences with them over the yrs .
I pulled a couple of plugs out at maybe 60k miles, and they still looked pretty good. The engine still runs as smooth as ever. I will at least check them again soon, and unless they still all look great, I will replace them. I have heard stories of plugs seizing in the aluminum heads over long periods of time, so I plan to use anti-seize and torque them to specification.
I know as a universal rule is that A/T trans fluid should be changed around every 30k miles because so much friction is cause by torque converter and M/T trans fluid is like 100k miles.
EDD512
Aug 27, 2019 07:45 AM
metrowerk
Dec 31, 2018 03:59 AM
Johnnyrod310
Jul 8, 2016 07:24 AM
kventura
Feb 26, 2008 10:11 PM
13lue
Jul 25, 2005 12:27 PM
