2004 Honda Accord Spark Plugs Q.
My Accord has 105k miles on it.
Just bought these " NGK Laser Iridium Premium Spark Plugs",
Model Type: IZFR6K11.
Car: V4. 4Dr. Honda Accord.
Did I get the correct ones?
Thanks.
Thanks.
Re: 2004 Honda Accord Spark Plugs Q.
Also, when installing the NGKs, don't use anti-seize on them.
http://www.ngkplugpro.ca/content/con...SparkPlugs.pdf
Enlighten me on the California model? I live and bought my Accord brand new in S.Cal. I looked up the make and # of the oem spark plugs and they weren't cheap. I need to change them out now, it has 104k miles.
For the California model, 4 cylinder which came with automatic transmission, the recommended NGK spark plug number was IZFR6K13.
Other 4 cylinder Accords (I didn't check if the V6 was the same) used NGK IZFR6K11.
The difference in the spark plugs were mainly the plug gap, as the last number on NGK plugs refers to that. The NGK plugs for the California model had a slightly wider gap.
http://www.ngksparkplugs.com/techinf...tnumberkey.pdf
The higher costs for the spark plugs are due to them being iridium. They have a longer service life and you do not adjust the gap on iridium plugs; so, as not to risk damaging the electrode.
As far costs between NGK IZFR6K11 and IZFR6K13, there should be no difference.
Thanks. By V4, I meant a 4 cylinder.
The spark Plugs cost me 60$ at an Auto Part store. At Honda they where 130$. Ebay has them for a much cheaper price at about 30$.
I live in SoCal, so I have to check if its a Cali model. Is there any harm in using the IZFR6K11 model on the Cali accord?
Same number as the 4 cylinder. The NGK number is (IZFR6K-11) (if it's not a california model). If you want to use Denso plugs the number is (SKJ20DR-M11). The rear bank can be a challenge, if you don't have the right tools.
Hi,
I found on this spark plugs in Forum about following, NGK Laser Iridium Spark Plugs
I am in Mississauga,Ontario and my car is Honda Civic 2012 , 4 doors,4 cylinder automatic,1.8 Liter .
Are above spark plugs best for my car and from where should I order online with free shipment,please.
Hi,
metrowerk
12-31-2018 03:59 AM
Johnnyrod310
07-08-2016 07:24 AM
kventura
02-26-2008 10:11 PM
13lue
07-25-2005 12:27 PM
