Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Spark Plugs location on 2004 honda accord v6
Old 09-17-2010, 07:11 AM
geesedude's Avatar
Default Spark Plugs location on 2004 honda accord v6
Where the hell are the spark plugs on a 2004 honda accord? What do i need to remove to gain access to them...?
Old 09-17-2010, 07:42 AM
LPED's Avatar
Default Re: Spark Plugs location on 2004 honda accord v6
There in the valve covers , under the coils .
http://www.hondapartsdeals.com/hpa/z...e&x=1107&y=553
Old 09-17-2010, 07:43 AM
kaiba's Avatar
On the head.
Old 09-17-2010, 07:44 AM
geesedude's Avatar
Ah, thank ya much. I looked all over the web and on youtube and couldn't find this simple answer...
Old 09-17-2010, 07:47 AM
geesedude's Avatar
On the same topic, i have less than 35k on my car. Do i need to even bother replacing them? Or is it case by case basis, after looking at the plugs for signs of significant deterioration?
Old 09-17-2010, 08:26 AM
My Name is Nobody
MSchu's Avatar
I dont think at 35k you need to replace unless you are suffering some performance or mileage issues. please refer to your owners manual for service intervals
Old 09-17-2010, 09:45 AM
geesedude's Avatar
Thanks - that's good advice. I just looked at my manual for the maintenance schedule, and it's not up for replacement until 105K miles! I also had in mind to change the AT fluid, but that's also after over 100k miles.
I guess i'm not working on my car this weekend...
Old 09-17-2010, 10:17 AM
My Name is Nobody
MSchu's Avatar
Excellent!
Old 09-17-2010, 11:23 AM
LPED's Avatar
Most newer cars list 100k for spark plugs . Personally I think I will replace or at least check gap condition at 60k and 90k and evaluate from there .
Your good to go for at least 2x+ what you have .
Old 09-17-2010, 01:32 PM
BLKFLSH's Avatar
I have 80k on my 03 V6, and I haven't changed the plugs yet, but I already have some new ones so I'm itching to do it. Personally, I would not wait until 100k miles to change the transmission fluid. Use "long life iridium tipped plugs" either NGK or Denso brand plugs. You can get the NGK plugs from just about any parts store, for about $10/plug. I only use Honda ATF-Z1 in the transmission, which is only available from a Honda dealer.
Old 09-17-2010, 02:29 PM
Bwill9886's Avatar
Agreed on both issues. I just don't trust Honda Automatics anymore... better to be safe than sorry.
Old 09-17-2010, 02:47 PM
LPED's Avatar
Right, that 100k is another 100k no maintenance marketing thing IMO . I would replace at half that at least .
Have you pulled any of plugs to see how they look in 80 k ?
Also on plugs get factory replacements, don't try an go cheaper with something like Bosh Platinum , had bad experiences with them over the yrs .
Old 09-17-2010, 10:12 PM
BLKFLSH's Avatar
I pulled a couple of plugs out at maybe 60k miles, and they still looked pretty good. The engine still runs as smooth as ever. I will at least check them again soon, and unless they still all look great, I will replace them. I have heard stories of plugs seizing in the aluminum heads over long periods of time, so I plan to use anti-seize and torque them to specification.
Old 09-22-2010, 05:17 PM
DELuth's Avatar
+1
Follow manual for plug replacement interval.
Service the trans every 60K.
Old 10-14-2010, 10:34 PM
jakefrom's Avatar
I know as a universal rule is that A/T trans fluid should be changed around every 30k miles because so much friction is cause by torque converter and M/T trans fluid is like 100k miles.
EDD512
08-27-2019 07:45 AM
metrowerk
12-31-2018 03:59 AM
Johnnyrod310
07-08-2016 07:24 AM
kventura
02-26-2008 10:11 PM
13lue
07-25-2005 12:27 PM
Quick Reply: Spark Plugs location on 2004 honda accord v6
