got code 9 need a bit of help
what is a cylinder sensor?
where is it located?
what does it do?
can i replace it?
any insight so i can get my mind around what this sensor is
95whitej1
what does it do?
can i replace it?
95whitej1
The sensor is inside and part of the distributor housing. Measure the resistance of the sensor and check the two wires with a multimeter. If the sensor is bad, you would generally need to replace the distributor housing.
I have gotten this code a few times. It always seems to happen when its super humid outside, and then after a day or so it goes away. Take off your cap and see if there is moisture in there.
Airbag Club
11
Mar 10, 2005 03:05 PM
quik89
Nov 30, 2003 06:43 PM
sander
Apr 25, 2003 07:46 AM
SpoolinEK
12
Jun 18, 2002 05:32 AM
