lower ball joint hitting rotor
I have a 96 civic hatch and i have skunk2 coilovers and camber kit. For some reason my lower ball joint hits my rotor when i turn. As you can see in the picture it has rubbed a hole in the shield. Has anyone ever had this problem and how do you fix it? and the hatch is not lowered that much.
ive had the problem... when undoing the ball joint.. the shiel usually gets bent towards the rotor and is scraping... which usually happens on turns but can also rub when the wheel is straight.. try and just pry the sheild away from the rotor as much as possible.... works every time, just use a screwdriver or pry bar
hmmm that's looks weird, i never had that problem or saw that happen...kinda looks like it could possibly be a bad wheel bearing. it's possible to rub but should never wear a hole through it like that
With your situation, just pull the shield away from the ball joint. There are other cases of this happening, but not with stock brake set-ups.
The wheel bearing on the pass side is brand new and it still does it there, and its not the LBJ thats hitting the shield its the LAC.
You guy's arent completely understanding wtf he's talking about... The LCA goes through the brake shield and grooves into the rotor, so it's penetrating deeper in than we can see...
Someone with an EK hatch can you go check ur LCA's and see if they curve up like that where the lower ball joint goes in... My EG's LCA goes straight it doesn't have that little curve up near the outer end..
Yeah that's what I'm saying... This is my cousins EK hatch "drtysoufchevy" so I'm trying to help him out a bit here but he lives across state or this issue would be fixed already hahaha... Naa but seriously, to me I think those are possibly the wrong LCA's or wrong Camber Kit making them touch at the bottom like that... When the front wheel is cambered in, it doesn't touch he said, but when the camber is set at 0 and the wheel is straight up/down it touches like we see in the pics... I can only imagine all the lovely noises that must make while doing 90 on I-75 lol...
the first original pic doesnt show the ball joint maxed out like that so what he is saying and showing are two different things.. the second pic that shows the problem is what should have originally been shown... i def agree its cause the camber kit is maxed towards the positive direction, which the original pic does show.... how is the other side looking...
Why is your camber kit all the way positive? My car is lowered the same amount and when I had a camber kit installed on my car I was adding 1 degreee of NEGATIVE camber. I have since removed the camber kit and am using stock control arms again. There is no need for a camber kit at that drop level. Your only reducing suspension travel with the upper control arm hitting the top of the fenderwell.
I've had this happen just recently.
Granted if you have stock brakes I would imagine something is broken or otherwise wrong.
Mine was because I have upgraded brakes. My understanding is this can happen with 4-lug systems with brake upgrades. The 5-lug (like ITR) don't suffer from this. So if someone is looking for a brake upgrade they might want to keep this in mind.
'98 EX coupe
- Fortune Auto 500 coilovers
- 11.1" Prelude rotors
- ITR calipers
- Buddy Club Roll Center Adjusters
- Skunk2 Pro camber kit (only did this because the a-arms needed to be replaced)
- New stock tie rods
Here's what mine looked like and it might give people a bit of an idea what this looks like when it happens.
We tried raising the car back up. Didn't help. In fact, the photo above was taken when the car was riding at damn near stock ride height. I was told to raise the car up, that the car was too low. Then I shocked them by showing how the car wasn't low in the least bit.
In fact, I had this problem, though not nearly as bad, when the car had the brake job, but stock struts and S-Techs.
Camber wasn't all stupid either. Everything was beautiful... except I was still having this problem.
As you can see in the photo the ball joint and the rotor were almost making contact all the time.
My solution was to get Spoon Sports 3mm wheel spacers from RHD Japan. Never had a problem since those have been installed. They're not expensive either.
Here's the rotor when I took it off btw.
And how low was I really?
http://imgur.com/AXoGN.jpg
http://imgur.com/hDBnQ.jpg
http://imgur.com/DGD5i.jpg
'98 EX coupe
- ITR calipers
'98 EX coupe
- ITR calipers
- Skunk2 camber kit (only did this because the a-arms needed to be replaced)
My solution was to get Spoon Sports spacers. Never had a problem since those have been installed.
'98 EX coupe
- ITR calipers
yeah I thought that it was the camber kit, so i just made it more neg. And it dont seem to rub anymore but the tires are deff cambered now. I originally had the car aligned at a shop. and thats how they had it aligned, so i figured they knew what they were doin since they are the only ones around NPR that kno how to align lowered cars or so i thought, haha
