ABS light after engine swap
Old Sep 16, 2010 | 06:33 AM
oranginal's Avatar
Default ABS light after engine swap
Throwing an ABS light shows Code1 when i jump it.
Light turns on after i get past 15-20mph
I recently did an engine swap so i am not sure if this is axle or clutch lines related or if i have to bleed the abs system or reset it in some way.
Can anyone point me in the right direction?
Thanks
Old Sep 16, 2010 | 07:35 AM
Kronn 98SH's Avatar
Default Re: ABS light after engine swap
I would do what the service manual suggests.
Old Sep 16, 2010 | 08:26 AM
Johnnytech's Avatar
Not sure what code 1 is but if you swapped axles you may have bent a sensor or the axles are not ones with the ABS ring on them. The ring looks like a gear on the outside of axle close to the wheel.
Old Sep 16, 2010 | 02:15 PM
oranginal's Avatar
Which is?
Old Sep 16, 2010 | 02:16 PM
oranginal's Avatar
used the same axels. not sure what the sensors look like but i will see if i can find a pic and look into this.
Old Sep 16, 2010 | 04:25 PM
Kronn 98SH's Avatar
Originally Posted by oranginal
Which is?
Get the manual and find out.
www.spoonertuner.com/manuals
ivan93egreppin210
Jul 22, 2009 07:27 PM
ILOVEGIRLS
Sep 29, 2001 07:29 PM
Rain_man
Aug 28, 2001 12:28 PM
Rain_man
Aug 28, 2001 04:32 AM
