trying to look for a turbo rebuild kit precision turbo
i have a precision turbo 50 trim t3 would i be able to get a basic t3 turbo rebuild kit or are they all different in other brands and such.
I know the basic garret kit's are all the same exept the seals
but i think the my turbo uses a dynamic seal since its pretty much new. but could i get a garret t3 kit or not
and also my garret turbo has a bad turbine wheel. do i order a wheel of any size i want or does it have to be the same size as the old one
thanks for any advice
must be the same size wheel/shaft as the old one. when you order one, it will come with a new shaft sealing ring, so you just need a standard 360 thrust bearing and bushing kit.
Do you have a SC5031? that uses a T31 exhaust housing and stage III turbine wheel/shaft
ptb 003-5031 which would refer to the cold side compressor wheel
and the other says thgt8-31
dkboyny11
Jun 14, 2011 07:00 AM
