is my head gasket going?
Old Sep 15, 2010 | 03:58 PM
Freshdot's Avatar
Default is my head gasket going?
sup, newly boosted d16z6..i've been dealing with colling problems ever since and have been seeing temps up to 220 degrees. Recently my friends have been seeing some white smoke clouds come from me at full boost, high RPM shifting. When the car is at idle, no smoke, normal driving, no smoke. only at high RPM's. Is this normal for a boosted car?
Old Sep 15, 2010 | 04:03 PM
Freshdot's Avatar
Default Re: is my head gasket going?
i recently read that this can be caused by the head lifting because i am using stock head studs. anyone else ever heard of this? also any ideas on how to keep my temps down?
Old Sep 15, 2010 | 04:07 PM
300whpej's Avatar
white smoke is a sign of coolant burning. also, boost on stock head studs will cause head lift more often than not. i would suggest you look into a new headgasket and some arp head studs.
Old Sep 15, 2010 | 04:19 PM
Freshdot's Avatar
yea i think this is the route i'm going to go..do you think this is what is causing my 220 degree temps as well?
Old Sep 15, 2010 | 04:23 PM
honda fossil's Avatar
a realll simple way of testing head gaskets is is to put on a no spill funnel on the rad and use a 5 gas tester to see if hydrocarbons(fuel) is leaking out and look for bubbling coolent
Old Sep 16, 2010 | 03:30 AM
Freshdot's Avatar
Uppp
Hiboost 2.0
Aug 12, 2011 03:37 PM
rippinitup01
Mar 19, 2007 07:42 PM
twkdCD595
Apr 20, 2006 03:39 PM
JTCdudeman
Sep 29, 2005 05:42 AM
EF9 CiviC SiR
12
Jul 9, 2004 09:56 AM
