Y7 Mini Me - Can I use Y8 head with z6 IM, TB, vtec, fuel rail and injectors?
Old Sep 15, 2010 | 12:02 PM
BuildingUp's Avatar
Default Y7 Mini Me - Can I use Y8 head with z6 IM, TB, vtec, fuel rail and injectors?
Whats up guys i have a d16y7 and was going to do a mini me swap with a z6 head so i got the z6 head, intake manifold, throttle body, vtec solenoid, head bolts, fuel rail and injectors. I was wondering if it would be possible for me to use all of these parts except the z6 head with a y8 head?
Old Sep 15, 2010 | 01:03 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Y7 Mini Me - Can I use Y8 head with z6 IM, TB, vtec, fuel rail and injectors?
yes, you'll just need to remove the blue plastic piece from inside your fuel injector plugs to make the OBD1 plugs plug in. Also you'll need to place the IAT into your intake arm as the Z6 has it on the manifold.
Old Sep 15, 2010 | 03:04 PM
BuildingUp's Avatar
thanks man also i was wondering if a d16z6 head gasket and head bolts could be used on a y8 head.
Old Sep 15, 2010 | 06:06 PM
BuildingUp's Avatar
bump
Old Sep 16, 2010 | 06:04 AM
tlarimer's Avatar
Sorry, had to reread and edit, I was confused for a second.
IIRC, you can reuse your D16Y7 headbolts, but if it were me, I would buy new headbolts.
If using D16Y8 head, use D16Y headbolts
If using D16Z6, use D16Z6 headolts.
skunk2eg
Feb 5, 2007 04:57 AM
keepinitsimple
Feb 17, 2005 11:32 AM
d15b7racer
Oct 16, 2004 07:27 AM
egturbo
Jun 14, 2004 04:05 PM
