Shock absorber troubles (installation)
Old Sep 18, 2002 | 04:46 PM
performula's Avatar
Default Shock absorber troubles (installation)
Old Sep 19, 2002 | 08:31 AM
Quik89Si's Avatar
Default Re: Shock absorber troubles (performula)
Yeah, I got Bilsteins and had to whack the forks into place from the bottom, with a mallet, at least on one side...it was such a tight fit that it stripped the paint off the bottom of the shock. I don't ever want to have to do that again, it was a PITA. But now I have to think about the fact that since there's no paint on the bottom of the shock, it could rust. Not good.
Alex
Old Sep 19, 2002 | 11:08 AM
Aron Parsons's Avatar
Default Re: Shock absorber troubles (Quik89Si)
wait, so your problem is you can't get the fork to slide into position on the shock? solution: grease, a couple of whacks with a hammer.
Old Sep 19, 2002 | 02:02 PM
wuhungsixxx's Avatar
New User
err....are you sure the "tab" is lined up perfectly with the slot in the fork?...even with a mallet it shouldnt take that much hitting...i did koni yellows in my teg and it wasnt too bad...dont feel to bad about the washer thing...did the same thing long long ago...IMO the rears are usually harder to install
astralshadow
Suspension & Brakes
12
Jun 14, 2010 09:51 PM
ak47autolock
Suspension & Brakes
Jul 5, 2006 07:33 PM
Jxi8s2k
Suspension & Brakes
May 29, 2006 04:06 AM
nEoMuGen
May 13, 2006 12:35 AM
DJtal Chaos
Dec 30, 2003 05:57 PM
