spark plugs cover in fuel?
Old Sep 14, 2010 | 10:40 PM
Silvertc's Avatar
Default spark plugs cover in fuel?
I was having sputtering problems awhile back due to dizzy. i put new one on, car ran good again then when i got to red light died. started it up and idle rough. drove it back took out spark plugs and they covered in fuel. What could be causing this? yes car is fully tuned....
Old Sep 15, 2010 | 07:16 AM
98integralsB18's Avatar
Default Re: spark plugs cover in fuel?
i dont know what it is tuned on but if it is a piggy back setup could be a problem or check your fuel pressure reg. and make sure its not leaking or anything vac./fuel.
Old Sep 15, 2010 | 07:31 AM
Silvertc's Avatar
not running piggin back. just tuned on Ectune
Old Sep 15, 2010 | 10:29 AM
ok thats good. do u have a fuel pressure gauge or anything along those lines to check the fuel pressure?
Old Sep 15, 2010 | 12:26 PM
TheShodan's Avatar
Moderator
This sounds mechanical. whether it is "piggy back" with the ECU or not is rather irrelevant.
Old Sep 15, 2010 | 07:14 PM
drs95ej1's Avatar
bro check your fuel pressure, same thing happened to me. got my car tuned and turns out he bumped up the fuel pressure wayyyyy to much and my plugs were gettin killed with fuel..
Old Sep 16, 2010 | 07:27 AM
Silvertc's Avatar
ya checked FPR and gauge it says 40psi...
Old Sep 16, 2010 | 08:37 AM
is the timed right? Since you said you put a new dizzy and **** on. another ? did u pull pull all the plugs or just one?
Old Sep 22, 2010 | 08:06 PM
Silvertc's Avatar
Yes, timed right. Still having issue, i have no idea what else it could be...Spark plugs are covered wet in fuel..
Old Sep 23, 2010 | 09:49 AM
Silvertc's Avatar
anyone?
1997boostedeg
Apr 15, 2012 11:15 AM
eagleclawracing
Mar 8, 2006 01:01 PM
RedRacerCivic
Oct 29, 2004 06:30 AM
csm84
Sep 28, 2004 12:47 PM
PM-Performance
Jan 30, 2004 01:16 AM
