95 civic - new starter won't crank engine
seen this title about 92 times before, but couldnt find an exact problem relating to mine. here the story, 266,xxx miles on chassis, (swapped motor, too many miles) d15b swap about 7 weeks prior to the starting problem. only mentioning the engine in case it could be part of my problem. i got home for lunch one day, started up right away on my way home. when i get back in my car it wont turn over, wont even try. lights and everything worked. after a bit of research, replaced my starter. wasnt the problem. did MORE reading, replaced the ignition switch. didnt fix it. so now i have a wire hooked to the starter, touching the battery post to start (hotwire) my car every time i have to go anywhere. i could push start it, but id rather not. someone had mentioned it could be a "clutch switch"? any help would be a big help. thank you. there is a killswitch but i know i hooked it up correctly, and ive tried hitting it several times. no response. SRS light is on, due to new ignition im guessing. i havnt reset it yet.could that be the problem?
just went outside and checked...and it IS missing. the day it stopped working i remember finding a little blue rubber piece on my floor. but i was so pissed off i overlooked the idea that maybe it came from up above... thank you everyone for the help. have a great rest of the weekend. im off to find where i put that little blue bastard.
mikej94civex
Apr 28, 2010 07:49 PM
ghost_ryder35
Sep 7, 2005 05:53 PM
