I need someone to help me rebuild my b16a
Ok.. heres the deal maybe you could tell me what is exactly wrong with it..I was driving/getting on because i haven't drove it in a while, i was going a decent speed and put it in the wrong gear and the car shut off and is not locked up...when it was together..the starter would turn and thats it...it just nothing else was going on..it sounded like it was missing something...Help please
How fast were you going? From what gear did you go from to what gear did you go to? seems like you blew the motor.....if you were going say, 65-70, and you decided to throw it into second from 3rd, or going the same speed, and went from 4th to 1st, possible engine failure is possible.
You most likely bent a valve.Do a compression check and see which cylinder has low compression and that will be where the valve floated and bent.
b20beast83
Oct 19, 2009 05:42 AM
