Porrman's Type R help!!!
Old Sep 13, 2010 | 01:51 PM
tstchatch's Avatar
Default Porrman's Type R help!!!
ok so i recently aquired a b16 hedad and supercharger setup... i have a B18C1 in my car right now. i pulled the head, put the b16 head on torqued head and cam caps down to spec, but when trying to rotate the assembly, i cant get the crank to turn a full rotation... its stoping about 15 degrees from being TDC.. is there anything im doing wrong? and anything in specific i need to know that deffers from a gsr-lsv-b20v setup? ive done all three of the previously mentioned but having issues now
thanks for the help HT
Old Sep 13, 2010 | 03:15 PM
boostedteg1203's Avatar
Default Re: Porrman's Type R help!!!
Sounds like the timing is off! The valves are probably hitting the pistons and stopping the crank.
Old Sep 19, 2010 | 11:25 AM
tstchatch's Avatar
ok i have the motor together, fixed the issue of rotation it started just fine... no leaks but a very rough idle, i understand it needs a tune, but im have park plug issues... the gap on my plug on cylinder 1 is getting pushed down (or up)/ the gap is getting pushed completely closed...WTF any ideas?
Old Sep 19, 2010 | 12:49 PM
delsolproblems's Avatar
Make sure that plug has its crush washer. Also make sure that plug is the same size as all the others. You might want to have a look at the valve clearances to see if there's a bent valve crushing the plug.
boostedblue23
Oct 21, 2018 09:18 PM
NIKADEM0
Sep 19, 2013 07:05 PM
CRXguy_88
Jul 14, 2011 01:40 PM
gutted-dx
Nov 8, 2009 08:31 AM
IN VTEC
Oct 2, 2002 11:37 AM
