RM M22x/Supertech valvetrain question
Old Sep 13, 2010 | 01:38 PM
Si Jeff's Avatar
Default RM M22x/Supertech valvetrain question
I did a valve adjustment using factory settings. .006" for intake and .008" for exhaust. everything sounded nice but now after 1,200 miles I'm hearing noise in the valve train. Since I'm using these cams should i be using different measurements? It's more noticeable when the I just start the car and goes away once the engine is warmed up. I'm using supertech valvetrain and that has about 29k miles on it. I purchased the cams and valvetrain brand new. Also when I'm in 5th gear and push the accelerator all the way down when going around 50mph it kinda make this loose change type sound.
Old Sep 13, 2010 | 05:37 PM
slowsleeper's Avatar
Default Re: RM M22x/Supertech valvetrain question
if the engine hasn't been tuned, that sound is probably detonation. Rocket cams actually require .007" intake and .009" exhaust for valve lash clearance.
Old Sep 13, 2010 | 06:46 PM
Si Jeff's Avatar
it has been tuned. since then though an edelbrock victor x im and a test pipe has been added. also i was tuned with 93 and the elevation of where i lived at the time was around 700ft. Now i'm stuck using 91 and at an elevation of 5,300ft.
Old Sep 13, 2010 | 06:50 PM
I am gonna say that elevation makes a difference..lol..especially the 4600 ft difference.
Old Sep 13, 2010 | 06:53 PM
koczeka's Avatar
lower octane and totally different intake manifold = your car is untuned
Si Jeff's Avatar
ill go ahead an do another adjustment though. thanks
Old Sep 13, 2010 | 09:01 PM
killer_Bseries's Avatar
Get it tuned asap also!!!! That's a big diff in elevation not to mention the new parts on it. Are you i n albuquerque?
Old Sep 14, 2010 | 09:21 PM
Si Jeff's Avatar
yea. just outside in rr.
mugen si
Jul 8, 2006 01:43 PM
EgxHaTcHxGsR
Mar 17, 2006 09:21 PM
sikcrx80
May 20, 2003 06:49 PM
infinkc
Jan 22, 2002 09:43 PM
civicboy95
Nov 18, 2001 02:51 PM
